MCD5000 SCENARIO CONNECTION
danvarcr
Mexico
Hi all,
Wanted to ask if someone has deployed an MCD5000 system, these are the requierements form customer.
1.- They want to use MCD5000 over their Network but the are not asking RGU or APX Consolettes, they think that MCD5000 can work without them. They are using a system called Open Voice, this works as an intercom system, they put up the handset of their station, press PTT and all others station along the network can hear the message at the same time, so they want to update them with MCD5000 but I am not sure of this one can work as that. Is it possible?
2.- They are asking one OMC server, but I read at the manual that one system can only handle 100 MCD5000 and not 133 as they are asking, they have to buy another OMC in order to have these 133 MCD5000 working at both systems, am I right?
3.- With no RGU or consolettes how these MCD5000 could have communication between them?
4.- Is it possible to connect 133 MCD5000 to the same VLAN and subnet to get the connection from each point to the server? What do we need to have this scenario working? I know that the customer needs to have already connection from each point to the central core, but what type of system configuration do we need, I read that we need to put IRC proxxy but I have not done this before.
Thanks to all.
Tech21
Talk to your Motorola dealer. Most of us here hook up MCD's to RGU's/Consolettes and don't attempt to use them in ways they are not designed or intended to be used. Chances are, it won't even work for your intended use.
It's designed to act as a control head for a remote radio to put it as simply as possible.
