Renfrew CACC - Medical Priority Dispatch System starting 9/5/24
Enjoi19
Ontario, Canada
What is MPDS?
Priority system for dispatching. Biggest change for listeners will be that instead of just Code 3 / Code 5, it's now 5 colour codes. Wikipedia page has this as being a UK thing, but Peel has been operating with that. Toronto uses the alpha-bravo-charlie etc for their 5 levels.
Forts
Ontario, Canada
Interesting... why are they using this when other CACCs aren't? Or are they all switching at some point?
webstar22
RenfrewCountyScanner.com
Ontario, Canada
Ottawa changed last month. Now they are pushing it to all the CACC's around that Ottawa pulls into their black hole of EMS coverage.
Everyone will be moving to it sooner or later.
Noseybody
Eastern Ontario Canada
Note: The color codes are a bit different in the above link are different from the ones used in Ontario, see below......
Patient conditions are given to paramedics are bit different also, letters and numbers......
Gotta be confusing for the ones that also go to Ottawa. I am in Ottawa's area, but Kingston CACC is a kilometer away and often cover calls in our area. Would have made more sense to do the change over for all of Ontario at once?
  • EMS Priority.pdf
w3rwn
MPDS better assigns priorities, reducing the number of code 4s.
They measured the systems by looking at how many times they dispatch outbound as code 4, and look at the actual return code after assessment by paramedics. The current dispatch systems over prioritizes, meaning a whole lot of outbound code 4s were coming back in as 3s or less.
OttawaBob
Ottawa, Canada
webstar22
Ontario, Canada
