Repeater Frequency
meech93
I have a question. If I put in a repeater TX 152.2775 and Receive 157.5375 will I run into communication problems or reflected power if my antenna is for 152-156? The receive will be a about 1500 MHz out of the antennas range.
Unlikely.
What kind of antenna is it?
The TX is well inside the range of the antenna. The RX side is not as critical and I would not worry about it at all. Likely it'll do just fine and you won't even notice a difference. Usually the antennas have a nice smooth SWR curve, so it's only going to be slightly out of tune on the RX side, and like I said, unlikely to impact performance.
You could go with a wider bandwidth antenna, but I don't think you need to.
I'd not get hung up on it, unless you are using one of those silly low profile soup can antennas.
meech93
Unlikely.
OK. Thanks for the info. I was going to use the Laird FG1520.
You'll be fine.
Antenna is spec'd to be 2.0:1 SWR or less over its range. I'd suspect it does much better than that. Either way, your TX frequency is well within that range. RX is more forgiving.
