Repeater offset?
Astrak
Mesa, AZ
What does a - or + sign mean on Ham radio repeaters is that the offset and if it is what is the offset of those?
W0JJK
Yes that is the offset of the repeaters.
"-" means the the input is lower than the output of the repeater. For example if the output is 145.235 with the "-" means the input to the repater will be 144.635
"+" means the input is the higher than the output of the repeater
so 147.06 with a "+" means the input to the repeater will be 147.66
Most 2 meter(144 Mhz) offsets are 600 Khz and the UHF offsets are 5 Mhz.
KC0LOD
Astrak
Mesa, AZ
Thank you Kc0lod and a question for you are you from Lincoln NE?
W0JJK
No. I am in the Omaha Metro area.
KC0LOD
Hoofy
Laurium, michigan
Astrack, as a rule of thumb the 2 meter repeaters in the 145. and 146. portion are almost always a negative offset and the 147. portion are usually the plus offsets.
W0JJK
Colorado uses "-" inputs on their UHF machines.
KC0LOD
nd5y
Wichita Falls, TX
Also some parts of CA, AZ, NV, NM, MD, NJ, NY, MA, CT and probably more that I don't know about use - offsets.
Some places even have + and - repeaters in the same area.
