Reprogramming PRO 106
helvis
Oceanside
Hello scanner folks. Does anyone know if a RadioShack / GRE PRO-106 scanner is still usable after the RCS rebanding plan? I programmed it a couple years ago and yesterday 9/17/18 Monday it’s dead quiet. I had no idea SD was rebranding so I checked radio reference and discovered it was.
I reentered all the new control channels from the north tower list, checked a few talk group IDs to see if they’re the same ( they were / Oceanside PD dispatch for example ) and I still get nothing. I went into the expert settings and made sure the splinter option and 800/900 was enabled. I did the TSYS analyze of the primary blue control channel and saw a 99% signal strength. What am I overlooking? Has my PRO 106 turned obsolete? Could anyone assist me?
Thank you
Helvis
K3OZO
San Diego, CA
Switch it from splinter to standard. I don't know much about the band plan support in that radio but I had to switch my setup in my Uniden 396XT to standard after the reband.
iMONITOR
Silent Key
S.E. Michigan
helvis
Oceanside
Thanks. It’s working. Solution was hiding in plain site. Your help is appreciated. Thank you.
