trimmerj
Looking for Proscan OFT dmr sample file for 996p2. Not seeing option to add frequency or talk group id's etc to system
Add Channel Button is Greyed out. Does the radio need to be connected for the additional menu items to show?
If you're aware of each talkgroup being carried on its own timeslot (For example, TG-1 only on slot-1 & TG-2 only slot-2) and you wish to do a channel hold on either talkgroup then it's best to program as OFT. Same applies if one slot is devoted to voice & the other for data (like LRRP) If traffic is only carried on one talkgroup & heard on one or both timeslots then you can program the frequency conventionally and be fineAssuming each Dmr frequency is treated as an individual system?
The options will look differently depending if a system, department, site, channel, or trunking frequency is selected too.I have been trying to follow these directions but, my Proscan page looks different and doesn't have all of those options? Am I doing something wrong? Do the selections/ page look different because my scanner is a sds200?
I'll try that!Yes screens are different because 996 is a small scanner and sds is not. You need to change the scanner type from sds200 to 996p2
