Reset of Cap+ "one frequency" sites
wbswetnam
DMR-istan
I don't know if anyone has been following this thread ( https://forums.radioreference.com/uniden-tech-support/356531-dmr-one-frequency-trunking.html ) in which I pointed out that the Van Buren County Sheriff's one-frequency trunk system does not receive properly in its current configuration.
As per UpMan's suggestion (post #9), DMR "one-frequency trunked" systems need to be reassigned as conventional channels for each talk group; i.e., Van Buren County Sheriff needs two conventional DMR channels, one for talk group 10 dispatch and a second one for talk group 40 tactical.
Thanks milf
INDY72
Indianapolis, IN
If it is an actual trs it will remain listed as such. If it is an actual conventional freq it will be listed once for each tg and slot used.
Sent from my LG-K330 using Tapatalk
INDY72
Indianapolis, IN
It needs confirmed by conventional monitoring with audio set to digital and tone search
That will show dmr or con or cap or dt3. If it shows DMR run it as oft for unidens. Or use DMRDecode or DSD+. Once its nailed down submit the corrections
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
In the thread, people have checked the 155.43 frequency with DSDPlus, and there is no indication that it is a Cap+ system. Although, the DB lists it as a Cap+ system.
So I believe he and Paul are suggesting that it (the Cap+ system) be removed from the DB, and replaced with appropriate conventional entries added for any talkgroups in use.
mike
INDY72
Indianapolis, IN
Will do once im home.
