rbritton1201
Captain1201
- Joined
- Jul 27, 2020
- Messages
- 407
- Reaction score
- 81
Reynolds County Sheriff changed from VHF Analog to what is listed below. I'm not sure I know which of these frequencies to enter into my Uniden BC536HP scanner, so that it will receive traffic from both the main base dispatch channel, car to base, and car to car traffic. Can anyone advise?
*WQQS915 - 852.0375 Base/Mobile Extenders, 807.0375 Mobiles (P25/NFM)
Also, I would like to enter the frequencies for Highway Patrol (Troop G), which is the Troop that apparently covers Reynolds County, Missouri, but can't seem to locate the independent MOSWIN or Analog frequencies for Troop G MSHP. Does anyone know the frequencies I should enter for Troop G MSHP?
I live in Franklin County, and want to enter Reynolds County, Missouri law enforcement into my scanner, so my brother, who lives in Reynolds County, can monitor their traffic via my scanner, along with what I have setup with respect to Franklin County traffic, and MSHP Metro and Rural Traffic in the St. Louis Metro area.
My scanner is set up as a server so that anything coming across the scanner can be monitored via cell phone through the internet. But, I'm skeptical that my scanner located in Franklin County, Missouri, is likely to even be able to receive signals being broadcast from Reynolds County, especially off of MOSWIN towers. I do have a VHF/UHF base station antenna in my attic, which is up about 20 feet off the ground that is connected to the scanner, and reception is very good in Franklin County and the St. Louis Metro area.
If it's not likely to be able to receive signals from Reynolds County, Missouri, when my scanner is located in Franklin County, Missouri, then I would probably give up on the idea of entering the frequencies into my scanner for Reynolds County, Missouri.
It just so happens that there are no feeds coming onto Broadcastify out of Reynolds County. If I thought my scanner in Franklin County, Missouri (Union/Washington, Missouri area) would receive signals from Reynolds County, then I might consider making my scanner a feed for Broadcastify. But, if there isn't much of a chance of receiving signals from Reynolds County, Missouri, then there is no sense in going any further with these endeavors. Please advise...Thanks!
| Frequency | License | Type | Tone | Alpha Tag | Description | Mode | Tag |
| 155.25000 | KQO319 | BM | Reyn Shrf Old | Sheriff: Dispatch [Ch 1] | FMN | Law Dispatch |
