WB4CS
I had a rather strange thing happen and can't figure out the cause. I'm wondering if something is wrong with my mobile antenna, and possibly getting RF back into the radio.
I have a Kenwood TM 281 in my car. Not using the stock mic (using KMC 30 no DTMF mic.) For almost a year I've been using a Larsen 1/4 wave antenna that's mounted on the top of my car on a drilled NMO mount. Yesterday I swapped the 1/4 wave for a new antenna, Comet SBB5NMO.
After mounting the new antenna and trying it out, I can receive very well and signals are much stronger than they were with the 1/4 wave. The radio was transmitting and I could bring up repeaters, but I had no audio. Confirmed buy listening to my transmissions on a handheld. Started troubleshooting the issue this afternoon and now I'm confused.
First, swapped back to the stock mic and audio was good and loud, but there was some static that sounded like the mic cord was loose. I could even wiggle the mic cord and make the noise worse/better. Swapped back to the second mic, worked perfectly loud and clear. Swapped the mic cables between the 2 mics, and had the same issues. Second mic worked but stock mic was scratchy. This is odd considering the stock mic has hardly been used. Now it gets weird. Changed back to the 1/4 wave antenna and both mics worked perfectly, loud and clear. Swapped back to the new anteanna, and both mics are working perfect, loud and clear.
To those with experience and not guesses, does this sound like an RF issue? Issue with the radio? Or intermittent mic issue?
Thanks!
Edit: I don't have access to an SWR meter or antenna anaylser, but that's my next step if the issue returns.
Thanks!
