XTL 2500 UHF
Galtar
I have a XTL 2500 that was working just fine. Suddenly TX has become garbled for both P25 and Analog. I swapped out the palm mic and it appeared to work again for a few days. Then went back to garbled. Is it possible that something internal has gone bad vs 2 different mic's suddenly stop working? RX has been fine when the TX worked and when it didn't. DOA? Need a new mobile? Thanks for any help.
16b
Central Ohio
What do you mean by “garbled” on analog? Noisy? What does the noise sound like?
Also, did you swap the palm mic for a brand new one? If not, it’s not that much of a coincidence to find two bad ones in a row.
But analog is a lot better for “earballing” things, so if we know more about the noise (a recording would help a lot), we might be able to provide more specific guidance.
Galtar
I can work on a recording but both the P25 and Analog come across as horrible static hiss that no voice is discernible at all. The analog will still open a repeater but thats about it.
Galtar
Purchased a new mic and all is well again.
