I have 2 each 996XT and BCT15X in my van, all with RH-96 remote heads. I have on 2 occasions now damaged the fragile front serial port on the scanner to the point where it will no longer remain connected.
I did a little poking around in a BCT15 and found the points in the radio where the cable connects and have been thinking of installing a 1/8 stereo jack on the rear of the radio to allow a more secure connection. This would also allow the use of a regular male-male audio cable to connect the radio to the remote head.
These connections are marked as "RXD2" (ring), "TXD2" (tip) and "GND" (sleeve). They correspond to those points on the male audio plug on the remote head end of the cable.
My issue is that these solder pads are obstructed by the front panel of the radio and are difficult to access for this fumble-fingers dude. I did try to find an alternate location to tap into these points to no avail.
Below is a photo of the daughterboard directly behind the front serial port/earphone jacks on the radio. (It is identical on the BCT15, BCT15X, 996T and 996XT.)
There are small holes alongside each pad but I can't verify that they connect to the solder pads.
My question is this:
Has anyone successfully remoted the front serial port for this purpose? Also has anyone found an alternate and easier to access connection point?
(I did try the rear serial port, there seems to be no continuity between the front and rear ports.)
