RISCON TRUNK ?
XPS720
Windham County, Connecticut
I am getting a strong signal on RISCON East but I hear no one. Do I need a special audio to hear any transmissions? I did notice that it shows RISCON is Global Filter and NAC-190
Thank You.
Whiskey3JMC
Simulcastylvania, TE
Do you have it programmed as a trunked radio system? Using an SDS200? Are the applicable service types turned on for the talkgroups you want to hear? (reference "tag" column in RRDB)
Whiskey3JMC
if you clicked the link I gave you it tells you how to access / turn on service types
Select Service Types
Press Func then Zip/Services.
Scroll to each Service Type and press E/yes to enable or disable.
W1KNE
Rooting out dumbasses since 2011.
Southern New England
Which Frequency are you hearing? Your profile says you're in Windham County, so unless you're way up on a high hill, I am curious how you're receiving it. Remember in the scanners, that the RX meter is for ANY RF detected on a frequency. So if you have 8 trunk frequencies programmed in, and the scanner sees RF on one of them, regardless of whom, it'll show in the signal meter.
