Do you have a 6 to 8 ft piece of coax?
If so, roll your own simple 850mHz indoor antenna. Here's how to do it.
1. Strip 5 or 6 inches of jacket from one end
2. Comb out the shield and twist the strands into 3 equal diameter "wires"
3. Strip about 2 to 3 inches off the center conductor.
4. Fashion a loop on the center conductor so that the length from the cable jacket to the top of the loop is 3-3/8 inches.
5. Cut each of the (former shield) wires to 3-3/8 inches and arrange them in a perpendicular plane to the center conductor so that they are approximately 120 degrees apart.
6. Suspend the antenna coax on a piece of non-conductive string from the ceiling above your scanner
7. Put a compatible connector on the other end and connect it to your scanner.
8. Turn the scanner on and prepare to be amazed.
73 Paul
73 Paul
