Router interference on scanner
Moose
New Jersey
I have a Cisco Valet wireless router that is interfering with my BCD536HP. It makes a loud high pitched background noise. Have to up the squelch to #3 to eliminate it but when a signal breaks the squelch the noise is still there. Anyone have this problem? I tried moving the router a few feet away but the problem still exists. Anyone have a solution?
krokus
Southeastern Michigan
Ferrite beads on the leads, as needed. Unplug them one at a time, and see which cable(s) have the interfering signal.
Sent from Tapatalk
FeedForward
Dallas
Check the router manual and see what frequency it is using; temporarily hook up the router with cables to eliminate the transmitted signal. Evaluate.
FF
brandon
SoCal
Shielded Cat6 will solve your problem. I re-wired all of my stuff with it a few years ago and the high pitched whining noise on HF and VHF Low is completely gone. I bought it from Monoprice for pretty cheap.
Moose
New Jersey
Sorry for the delay getting back to everyone's suggestions. Been busy with a sick dog and haven't had a chance to reply. At work now but will go at it this weekend. Will update on what works for me. Thanks
cg
Connecticut
I would suggest that you also check the power supply for the router as it may be the culprit. Find another wall wart that matches voltage and polarity and try that.
I relocated all my computers and internet equipment 15' or more from my scanners. Extension USB cable, monitor cable, sound and microphone cables. Cut down quite a bit on interference.
chris
iMONITOR
Silent Key
S.E. Michigan
I have read numerous post on RR over the years, regarding this problem. It's odd, as I have never experienced interference from any routers. I've owned Linksys, Netgear, D-Link, and currently a Motorola. Same goes with computers and monitors, never a problem.
