Row Data from DSD Plus
tuky
Hello,
I don't remember.
How can record raw data to send a DSD plus manager to solve a problem: understand because certain data it's LOCN and no LRRP.
Only LRRP give me speed and direction.
ThankYou
Reconrider
Inside the Galaxy
Radio Galaxy
If you want to send any data to the dsdplus coder/owner, you need to put it in a zip file and email it to him.
But he's not going to fix an issue that's something your system isn't producing. Not all systems produce everything you want it to.
u2brent
OAMPT
KRWDPAXKRS1
R starts the recording not sure if the focus needs to be on DSD or fmp24 window..
tuky
Ok, I have checked.
I think it's in DSDPlus in menu Input/Start Source Audio Recording or Start Source Audio Recording As
u2brent
OAMPT
KRWDPAXKRS1
Ok, I have checked.
I don't believe those options are for initiating RAW recordings. Just WAV or MP3's.
cg
Connecticut
While in DSDPlus window, press R to record the raw audio. Press R again to end recording.
If you do this with the FMP window highlighted, it creates 2 files, .FM and .IQ. I believe this is the raw recording of the entire bandwidth of the SDR in use. It will be a huge file and can easily be gigabyte sized. For example, I just did it and a 2 second recording with a 2 MHz wide SDR created a 18MB file.
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Source audio recording is "raw audio". It records the raw audio in .wav or .mp3.
Ok, I have checked.
That is correct. Start the recording. Once you know you've captured the event you want to capture, turn it off. It'll put a file in your DSDPlus folder starting with DSDplus-Raw-Input_YEAR-MO-DA@######.wav. That is what you would send to the author.
Of course, make sure you send "good" audio. If it's weak audio or audio with interference it won't do much good. And, like somebody else already said, not every system sends full LRRP data.
