RPM2 without ASK
angus_fiedler
Hello,
I am looking into purchasing RPM2 to program our agencies do-75 radios. I know with CPS I am able to change the order of zones and add conventional frequencies even without a ASK. Is this possible with RPM2? Or do I require an ASK even to change the order of talk groups within zones / add new conventional frequencies.
Thanks!
K2NEC
NA
There is no such thing as an ASK with Harris. The "system key" is an AAC in RPM2 and it's a physical dongle that you need in order to be able to verify the licensing on the software and use it. There's a download version as well that acts a little different.
Essentially you need the dongle to even open RPM2. And said dongle also needs to make sure it has all of your trunking system information on it if you are editing trunking personalities.
BMDaug
I am licensed…
Central Colorado, USA
There is a legitimate download/CD installable version of RPM2/RPM14 (It’s bundled). That license is permanently installed to a single machine, where the dongle licensed version may travel to different computers via the dongle. You save a few hundred bucks but lose the ability to move to different computers.
The system keys are often stored on separate dongles and you plug in the one(s) for the system(s) you are working with. This is usually because those system keys are supplied to you by the authorizing agency.
There is a provision for virtual keys within AAC, but most agencies don’t trust them. So it is technically possible to use RPM2 in a completely dongle-less mode, but it it very uncommon.
The CD distribution works well for me because I travel with the computer, which has limited USB ports and I don’t want to deal with losing or damaging the license dongle and being dead in the water! I still need system key dongles, which already eat usb ports.
-B
IFRIED91
Arrive alive
NYC area
-B
Using RPM2 dongle-less does not go well with the latest Windows 11 updates.. something with Microsoft net framework
cvk14
Hello,
Thanks!
I believe in the RPM2 14D release, you can manage the data on the radio not locked by the distribution key (aka ASK key). any trunk systems are greyed out, but you can assign the trunk talkgroups to zones and rearrange the order of the talkgroups in the zones.
IFRIED91
Arrive alive
NYC area
Good thing I’m on Enterprise LTSC 2019! Supported until 2029 so I’m stickin with that where everything works…
-B
So I was reading posts on other sites and saw something regarding windows 11 messing with bonjour
BMDaug
I am licensed…
Not surprised… I’m immune to all that windows 11 crap. That’s the beauty of enterprise. You get the security patches but not any driver breaking feature “upgrades”…
-B
