RSS Computer Requirements
JerryX
I'm about to start the process of buying RSS from Motorola to re-program some HT-1000 and Sabers and I noticed that this software runs under DOS on old, slow computers. Does anyone know if RSS will run under DOS running in a VM (VirtualBox or VMware) on a modern Windows 10 machine?
Mr_Boh
The Land of Pleasant Living
Those including DOSBox have worked. The worst I have heard of is you need to explicitly slow down the clock speed on the DOS instance to improve reliability... can't remember for which specific models, I just remember that being a thing with virtualizing/emulating DOS-based RSS
IAmSixNine
Dallas, TX
I dont believe motorola sells that anymore. Its way past its end of life for hardware support and software support.
As far as computer goes, you need an older slower processor as well.
a417
It will run in DOSBox but you will likely brick the radio writing to it.
You need old hardware to read/write reliably.
I'm running an old Windows XP laptop. I downloaded a program called "RUFUS" onto a thumb drive. RUFUS is DOS that will run on the USB drive. I just boot up the machine off the USB stick. The RSS software resides on the same thumb drive. Has worked just fine for HT-1000's, JT-1000's, GM-300's, etc.
cmdrwill
So Cali
+ one for mmckenna's way . I have a triple boot on my shop computer.
And for sure you may brick a Jedi using things like dosb0x.
a417
...to read/write to the hardware. I have been safely using dosbox for editing codeplugs for many years, in many case-use scenarios.
wa8pyr
Staff member
Lead Database Admin
Ohio
Ditto. I've programmed older Motorola and GE radios using Rufus on a thumb drive booted on my Toughbook CF53. Works like a champ, even on Maxtrac/Radius, MSF5000, etc. In fact, I copied nearly the entire hard drive from my old 486 laptop (the display died) to the Rufus stick, and now the Rufus stick acts just like my 486 laptop, including the GUI menu program that opens on boot.
Easy peasy.
JerryX
What are my options if Motorola doesn't sell it anymore? (Note: I'm not interested in an illegal copy of the software--I want to keep this entirely above board). Are two-way radio shops likely to still have this software and would they be willing to program several radios for me? I just need the radios set up for a few 2M repeater pairs and a few simplex frequencies.
wa8pyr
Staff member
Lead Database Admin
Ohio
Highly unlikely Motorola sells it any more; last time I checked my MOL account a few weeks ago there wasn't anything listed as available older than Astro25. Your only option would be to find a shop that still has it and can do the programming.
Nasby
Ohio
Maybe try posting a want ad in the Classifieds section.
I've seen lots of folks offering programming services in the past.
n3obl
ØAES-1056
PA
Honestly those programs are old enough that a simple google search would find download links and I highly doubt motorola would expend any effort in locating you. They have been NLA for a number of years now. I use a toughbook with win 7 32 bit to run all windows stuff and a 2gb USB flash drive with ms dos install on that to run the older RSS stuff. Works like a charm.
N4KVE
PALM BEACH, FLORIDA
Several years ago I sold a XP laptop to a friend who wanted to program MTS2000’s. The laptop had never programmed radios before. He literally went online, & found the CPS in under a minute. It had been NLA for years. RSS would be even older.
