RSSI motorola cdm750 uhf
ratbasterd
findlay, ohio
hi i have two cdm750's for a repeater and would like a s-meter i see the rssi pin 15 of acc conn should be 0-2.5v but it is 1v-2.5v do i need a pull down resietor
to pull it down to 0v ?
thanks.mike.....n8rtn
jeepsandradios
East of the Mississippi
How are you measuring it ? I have one setup at home for some stuff with an analog meter. It sits on the bottom of the scale until audio comes in.
ratbasterd
findlay, ohio
hi iam measuring it with a analog volt meter what pins are you using?
mine works fine just sits at 1volt...till it gets a signal.
mike....
