Mountaineer304
Gonna be mainly programming my Yaesu FTM-500D via ad card, my Ft710 and some baofengs and maybe an anytone... Is there any advantage to RT systems vs chirp or factory software??
YES. RT Systems software is Far better than chirp. Almost everything I have is programmed using RT.Gonna be mainly programming my Yaesu FTM-500D via ad card, my Ft710 and some baofengs and maybe an anytone... Is there any advantage to RT systems vs chirp or factory software??
What about the yaesu factory software? Also benefits of et systems?YES. RT Systems software is Far better than chirp. Almost everything I have is programmed using RT.
ADMS is Yaesu's proprietary software is ok, but Can be buggy, depending on the radio and what you're trying to do. None of that happens with RT Systems . No issues with drivers, or port problems. it just Works.What about the yaesu factory software? Also benefits of et systems?
I have bought three RT programming systems and had very good experience with all of them. The first one I had a question on a Saturday, sent an email, and got an answer within a couple of hours.Gonna be mainly programming my Yaesu FTM-500D via ad card, my Ft710 and some baofengs and maybe an anytone... Is there any advantage to RT systems vs chirp or factory software??
Mainly need it for my FTM-500 which I’ll use SD card with and my ft710 if I even program it..Positive, their stuff works.. If not, they'll help fix it. The support is top notch as others have said.
Negatives.. Proprietary cables... Their software doesn't like OEM or aftermarket cables except theirs, at least in my experience
The positives outweigh the negatives.. I've never had an issue with their software or cables.. The software is easy to use, and the cables are overbuilt.. Think I could tow a small car with my Icom or Yeasu cables from them.
I think you'll like it. Makes programming anything much easier and enjoyable. Good luck with your 500 & 710 !Mainly need it for my FTM-500 which I’ll use SD card with and my ft710 if I even program it..
Which is clearly a disingenuous statement because their radios, like most radios these days, all use software in the form of programming instructions coded into their radios. That's been true as long as radios have included microprocessors. It would be more believable if Yaesu would say that they don't spend as much development effort on their radio programming software as they do on their radios.Honestly, I like Yaesu gear, but their software is nearly unusable. Their excuse is 'We're a radio company, not a software company'.
As others have already said, RT is the best going. (I have the RT packages for 13 different Yaesu radios in my computer.) The factory software can be prolebmatic at times and it doesn't have all the features the RT product. Under no circumstances should you ever program a Yaesu radio with Chirp, especially the digital Yaesus. Chirp can brick the radio and Yaesu has stated on numerous occasions they won't repair radios damaged by using Chirp.Gonna be mainly programming my Yaesu FTM-500D via ad card, my Ft710 and some baofengs and maybe an anytone... Is there any advantage to RT systems vs chirp or factory software??
You'll have to buy separate software packages from RT for each radio. There is a caution on the RT website about the firmware version on the FT-710.Mainly need it for my FTM-500 which I’ll use SD card with and my ft710 if I even program it..
I think you're absolutely right about that. Why put more effort into something you're giving away for free?Which is clearly a disingenuous statement because their radios, like most radios these days, all use software in the form of programming instructions coded into their radios. That's been true as long as radios have included microprocessors. It would be more believable if Yaesu would say that they don't spend as much development effort on their radio programming software as they do on their radios.
I was put off by the Chirp dislaimer when you launch the software that says, in essence: "You may brick your radio."I have spent hundreds on the RTSystems software and cables. Fantastic customer service. Easy to use software and my favorite part is the easy copy and paste of frequencies between different radios, even if one is a transceiver and the other is a receive only radio…and even when the frequency coverage differs. When radios began using the MicroSD cards the cables were no longer necessary for programming.
I use Chirp with cheap Chinese radios. With Chirp you get what you paid for. With Chirp you may also get what you do not want, like it or not.
The USB Cable provided by RT systems is far superior then any other third party programming cable. I have used the RT Systems cable with CHIRP, but found RT's software far superior then CHIRP. IMHO.Gonna be mainly programming my Yaesu FTM-500D via ad card, my Ft710 and some baofengs and maybe an anytone... Is there any advantage to RT systems vs chirp or factory software??
