moonbounce
- Joined
- Nov 5, 2002
- Messages
- 1,452
- Reaction score
- 84
First, are you certain you don't have the SHIFT enabled?
If you set the PPM, it should be set everywhere. Your PPM does not change in different bands. If that truly is happening, your dongle is bad. Once you calibrate the PPM, it's calibrated everywhere.
I checked my airband earlier, and I get lots of activity. I can't hear the ground stations (too far away), but lots of activity.
You say you want to hear the airband, but you say you're tuning from 24-30 MHz. The airband is 118-136 MHz.
Shift is not enabled.
I am not a simpleton, I know where the air band is. I was scanning 24 - 30 Mhz because I wanted to check another AM band to see how it was with the dongle.
MB
