DSDPlus RTL V4 Error -5
vince48
Central Valley, CA.
Greetings
I'm trying to use my new RTL V4 dongles with DSD+ (Fastlane) and I keep getting "device is in use" I have no other dongle open.
When I run RTL 32bit program I get this while reading the eeprom.exe
rtl-sdr-32bit-20240707>rtl_eeprom.exe
Found 1 device(s):
0: Generic RTL2832U OEM
Using device 0: Generic RTL2832U OEM
usb_open error -5
Failed to open rtlsdr device #0.
What am I doing wrong?
PDXh0b0
Woodland, WA
Make sure all other programs are closed, if it persists pull/plug the dongle... dsdplusfastlane...what are you running, in what order?
BM82557
Berkeley Co WV
Did you install the specialized drivers required by the V4 as mentioned in this release announcement ? --
PDXh0b0
Woodland, WA
vince48
Central Valley, CA.
if I install the driver in the dsd+ folder , I get a check sum error
PDXh0b0
Woodland, WA
still no joy, same error,
For the rtl-sdr-blog v4 I had to run zadig specifically for the v4 (you only need to do this once for blog v3 and nooelecs, and once for blog v4)
If you've done that already, you'll need to download the basefiles, run dsdplus.exe, in the dsd+ 1R event window, go to Misc/download newest base files..
It will download to your dsdplusfastlane folder, extract it, open the dsdplusbasefiles folder, in it open the dlls folder, copy the rtlsdr_V4.dll and paste it into you dsdplusfastlane folder
sonm10
Central MN Monitor
Sauk Centre, Minnesota
Might want to check Windows Defender is not blocking the link between fmp24 and dsd+. I think I had to allow an exception in Windows Defender.
vince48
Central Valley, CA.
I have the latest base files, I did that first since its ben written the newest base file has the rtl.dll to run rtl V4
in zadig, which driver do I use?
vince48
Central Valley, CA.
no, I didn't get any notices from Defender when trying to run DSD+ nor trying to open the V4
vince48
Central Valley, CA.
yikes, after I ran zadig, still no joy
C:\Test DSD RTL 1>FMP24 -rv -i2 -o20002 -P0.0
FMP24 2.76
Current working directory is "C:\Test DSD RTL 1"
SDR sampling rate = 2.400 MHz
Spectrum window width: 1024
FFT size: 32,768
Spectrum update rate: 10 Hz
Step size table: 5.000 6.250 7.500 12.500 15.000 25.000 100.000
DSD+ path is "C:\Test DSD RTL 1"
Primary frequency list: '.\FreqList.csv'
Secondary frequency list: '.\FreqList2.csv'
Database search distance: 99.90 miles
Base latitude/longitude: 19.7163 -155.6241
Role is voice channel monitor;
Auto-starting voice following mode
Using RTL SDR device #2
Using DSD+ link ID 20002
PPM correction set to 0.0
Optimizing FFT calculations... done.
Audio output device #1 = 'Remote Audio'
SDR device count = 2
SDR device #1 serial string = '00000001'
SDR device #2 serial string = '00000001'
usb_claim_interface error -12
rtlsdr open error = -12
Can't open RTL SDR device #2
PDXh0b0
Woodland, WA
If you use teamviewer and want to give that a shot send me a message
slicerwizard
Toronto, Ontario
Original source: http://www.unitrunker.com/v2/fga-zadig.html (now 404)
Problems like this are usually caused by installing the USB driver for the wrong device.
Unplug all dongles, then use Device Manager to delete them.
Plug in a dongle and then do the following:
Run Zadig.
Under Options,
make sure to select "List All Devices"
and unselect "Ignore Hubs or Composite Parents".
Then choose the dongle's Composite Parent and install the driver.
