Russian Airforce HF
ACADEMIContractor
XE Services/Academi Contractor
My old files enjoy.. Very active, note use a good LNA and SDR DUO and of course good antenna
Since my last Post on the British Intel near Russian base these freqs are jumping
Russian Air Force Stations
Note: This information can change at any time
Frequency (MHz)Signal ModeCallsignNote
2.737CW / DigitalREA4Air Force HQ Moscow
3.633CWCEJX
4.179CW / DigitalREA4Air Force HQ Moscow
4.672USBVologda RadioSometimes call checks Il-76
4.755USBBlesk 37 Ja Skat 07Possible Air Force use
5.312CWRussian Strategic Air Force TU-95 ground CW frequency
5.620CWRussian Strategic Air Force CW Ground Frequency
5.832CWRICARJ72131, 72132-TU-22 from Renchovo
5.835CWRussian Strategic Air Force TU-95 CW ground frequency
6.685USBPROSELOK
KORSAR
KLARNETIST
Traffic control comms air force
Chkalvosky Moscow Region
7.940CWREA4Air Force HQ Moscow
8.029CWRussian Strategic Air Force Bombers TU-95 CW Ground Spring Primary Frequency
8.090USBNABOR
SHAPORA
Russian Strategic Air Force Bombers TU-95 Spring Frequency
8.033USBRussian Strategic Air Force Bombers TU-95 Autumn Frequency
8.112CWBALANS KATOLIKRussian Strategic Air Force TU-95 CW Winter ground frequency
8.131USBBALANS KATOLIKRussian Strategic Air Force Bombers TU-95 Winter Frequency
8.162CWRussian Strategic Air Force Bombers T-95 Ground Autumn Primary Frequency
8.170CW 6PLS D2WDRussian Strategic Air Force Bombers TU-95 Spring Air CW Frequency
8.816CWNaval Air Transport
8.847USBTraffic control comms air force
8.895CWRussian Strategic Air Force TU-95 Summer CW Ground Frequency
8.909USB OCHISTKA, PROCELKARussian Strategic Air Force Summer TU-95 Frequency
8.252USBRussian Air Force Unknown Unit
9.027CWRussian Strategic Air Force TU-95 Bombers Autumn CW Air Frequency
9.128CW P7YR W6SY QYYIRussian Strategic Air Force TU-95 Bombers Summer Air CW Frequency
11.072CWREA4Air Force HQ Moscow
11.354USBRJF94 / NOVATOR
PRIBOJ
KROCKET
Russian Naval Air Transport Command
11.360USBPROSELOK
KORSAR
Chkalvosky airfield
Moscow Region
18.030USB KORSARTraffic control comms air force
Known Russian Strategic Bomber VHF frequencies: 124.000 128.500 136.250 138.550 284.650 289.000 358.125
Notes on TU-95 and TU-160 Strategic bombers communications:
If the TU-95 CW markers are active its an indication that bombers are in the air and its possible to monitor USB frequencies. Every 20 minutes lasting for 2 minutes a single letter will be repeated by CW. Its always on the H+00, H+20, H+40 and normally handset. Commonly marker W is heard probably from Moscow Strategic and Long Range aviation headquarters. G marker possibly comes from Russian Ukrainka Air Base in Amur District in Far East Russia. Other undefined markers are Q, R and Z. C marker is used by TU-95 bombers used by Russian Navy from Moscow Naval HQ. Arkhangelsk Severomorsk naval base use S marker.
The bomber formations use callsigns. Known callsigns are TRL5 – Spring TV6P, IZ2J and KFE4 – Summer 4ASU, QZ6Y and PUO7 – Autumn IWV4 – Winter. Three figure groups are used in messages, although is speculated that five-figure groups are actually used.
The ground communications to aircraft using USB voice use callsigns such as NABOR, BALANS and KATOLIK that are fixed and are not affected by the seasonal changes.
Usual message format callsign, the air unit number and coded numbers group that holds itself navigational directions.
KATOLIK for 48123: (unit number) / 694 062 405 274 527 /
During the flight, these navigational readings are sent frequently, because of bad readability the radio operator must repeat the message groups frequently. The female operator heard often is operator from the ground stations.
However, it’s been observed that also Monolith type messages similar to those used by ground forces are used. In this case, the format and reading conduct are similar to command message send on S30 the Pip
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
No LNA when the antenna and propagation is good. It will just increase the noise along with the signal.
These stations are covered in the UDXF reflector on groups.io. Interesting list.....Mike
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Appears that this list was lifted from here:
Credit where credit is due.
