S.I.M. now on SERAM
RickoBev
Montreal
Did someone has TGID's of the tactical frequencies?
I mean TACx frequencies.
I'm talking about SIM.
I know TAC frequencies are posted but i'im asking if someone has the TGID's from these freq.
Thanks for your help
VORTAC
Montreal
I do not think SERAM have programmed TG but simply a Nac code. Typically, they are in "293" series and up.
RickoBev
Montreal
Thanks for your help.
a few last last question about SIM-SERAM,
1- would it be better to leave a check at Box "ID search" or should i check "ID scan" when programming my scanner
2- Anyone can confirm if Uniden 996P2 is working as well as 325P2, 436HP and 536HP ??
Thanks again
mtlfirebuff
Montreal, Quebec, Canada
For your information a new BCD536HP scanner online for the SIM feed as of 1/27/2016.
Pour votre information un nouveau scanner BCD536HP en-ligne avec les ondes du SIM depuis 2016-01-27
quebecradioguy
Quebec Database Admin
St-Eustache Quebec Canada
Il serait aussi important d'updater la description du Feed avec les groupes qui sont feeder. Ce sont encore les groupes de l'ancien système qui sont inscrit
quebecradioguy
En fais, je parlais plus des Feed notes et non du feed status
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
May I suggest you try to get Official Feed status from Broadcastify? If I recall correctly all you have to do is have a letter sent to Broadcastify on official letterhead with the feed identification and the user name of the feed provider.
