Safe-T analog channels
IndyRick
Indianapolis
Howdy, folks!!
I'm not understaing safe-T very well...hope you can help with a couple of basic questions.
I'm wanting to monitor the Safe-T analog groups, which I understand are the highway deptartment and mutual aid.
Do I enter all the Safe-T frequencies and lock out the digital talkgroups, or do I use these frequencies?
Frequency Input
Type Tone Alpha Tag Description Mode Tag
866.01250 821.01250 RM 156.7 PL CALL Calling (Indianapolis Site) FM Interop
866.51250 821.51250 RM 156.7 PL TAC1 Tactical 1 (Indianapolis Site) FM Interop
867.01250 822.01250 RM 156.7 PL TAC2 Tactical 2 (Indianapolis Site) FM Interop
I'm using a Pro-97.
Thanks, all!
(I searched the forums, and either I'm not understanding what's posted, or am not phrasing my question correctly)
GTO_04
Noblesville, IN
Just enter the SAFE-T control channel frequencies and the analog talkgroups only. I do not have a Pro-97. Does it have "control channel only" mode. If it does, that is what you want and you only need to enter the control channel frequencies.
GTO_04
AK9R
Staff member
Super Moderator
Central Indiana
I think you are looking at the wrong thing.
The SAFE-T analog channels are trunked just like the digital channels. You program your scanner as if you were programming any other analog trunked system. If your scanner can do control channel only trunk tracking, program just the control channel frequencies. When it comes to progamming talk groups, program just the analog talk groups because you won't be able to monitor the digital talk groups with an analog scanner.
You will find the SAFE-T control channels and talk groups listed here: http://www.radioreference.com/apps/db/?sid=933
The frequencies you posted are for the conventional non-trunked interoperability channels. You would program them like you would any other non-trunked system on VHF or UHF.
The SAFE-T conventional interoperability channels are listed here: http://www.radioreference.com/apps/db/?aid=4017
Note that the SAFE-T trunked frequencies are not the same as the SAFE-T conventional frequencies.
