Saia net
joespca
Amherst NY
I see erie county sheriffs have a patch on saianet. Is it encrypted on their system? And if so why would it be encrypted if the conventional channel for the sheriffs is open? Could this mean they are going encrypted in the future so they wanted to set it up that way on saianet?
Whiskey3JMC
Lemme show ya sumthin
Simulcastylvania, TE
Database says yes. Mode "TE" indicates full time encryption. My guess is they're most likely phasing out the conventional
DECModeAlpha TagDescriptionTag
500110TEECSO Ch 1 PatchSheriff Ch 1 PatchLaw Dispatch
joespca
Amherst NY
That's for saia net DMR. Erie county sheriff just switched to P25 within the last 5 years. I find it hard to believe they will get all new radios and switch to saia net system when they just upgraded to P25. I don't have a scanner to scan saia net just thought it was weird they had their patch encrypted.
ak716
'Merica
Per DSD, it's running Enhanced Privacy/RC4 too, as of 30 seconds ago. Why? I have no idea. It's usually active on the Perrysburg site only, from my findings at least. I thought, I could be mistaken, but I thought it was running Basic Privacy for a while.
I'd be hard-pressed to believe ECSO would be switching to SaiaNet. They have upgraded a lot of their portable radios from XTS1500's to APX4000's over the past few years, and I've even seen an NX-5300 kicking around that I was told they were testing.
When they converted, they were using their XTS1500's in analog, and were for years. When they upgraded, they didn't fleetwide buy new radios. It was just a programming thing.
GTR8000
NY/NJ Database Guy
BEE00
Well...what's the reasoning then?
The larger point is that if you're not from the area, and clearly have no familiarity with the area, it's probably best to refrain from constantly chiming in with posts that are quite often erroneous and/or unhelpful. ;)
ak716
'Merica
Unconfirmed, but HIGHLY SUSPECT that SaiaNet TG 500111 (active on Site 3) is a patch of ECSO Ch 2. Unconfirmed because it's running Enhanced Privacy, but the activity matches up perfectly to their clear analog channel.
joespca
Amherst NY
Wonder why encrypted on Saia net but not on open channel ? Maybe concerned it makes it easier to monitor their channel ?
