Sarnia EDACS
LesWurk
Land of RF
for many years I have had this system programmed
1 858.0625
2 858.5625
3 858.8125
4 858.3125
5 859.0625
I don't know where the extra channel came from, and don't believe the database on Radioreference is correct.
When was the system updated?
I don't follow the system that much but it seems to work the way I have it programmed. Its not very active so I cannot verify much at present.
yooper927
St. Clair County, MI
Hey Guys, I have my scanner programed just like LesWurk has posted and it tracked Camlachie fire just fine a little while ago. The system is very quiet and 858.56250 is the current control channel right now.
1 858.0625
2 858.5625
3 858.8125
4 858.3125
5 859.0625
VE3JSO
sarnia ont
ok thanks for the update i give it a try pulling my hair trying to get it to work
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Hi guys , just read this thread and updated the database.
Thanks for passing along this correction. :)
MilBil
Sarnia Ontario Canada
Are you sure that this will work programed this way because the freq. are not in LCN (Logical Channel Number) order ?? The way you updated the database .
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Forts has mentioned that he will be in Sarnia between Wed. to Fri. . I will let him report back what he has found. If any changes need to be made again, I will do them.
Members had mentioned that what was previously in the database did not work.
VE3JSO
sarnia ont
i am in sarnia listening in to edacs system so far no luck but i am not sure if i have the lcn order right
VE3JSO
sarnia ont
that's way i have it how often is there a pager test for the county i know about the sunday night one
Forts
Ontario, Canada
Thanks for checking this out guys... I'm in Sarnia tomorrow and Thursday so I'll be able to keep an ear on it too (and let Unitrunker run at the same time).
Forts
Ontario, Canada
It looks like what is in the database now is correct... Lots of accidents out on the 402 this morning in the snow and I had no issues listening to the departments involved. Seems like maybe some bad data got submitted to the database somewhere along the lines, or maybe something just got messed up. Anyhow, seems ok now!
