satellite phones
poltergeisty
Truth is a force of nature
Banned
RLG, Fly heading 053, intercept 315 DVV
So I'm thinking of buying one and would like more info. on them. A couple of questions.
A) How do the phone cards work. Is it like Trac Phone or Straight talk?
2) There are so many phones on Ebay, which one to get under 400 bucks? I would like to get a cell phone sat phone combination unit if possible.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Wirelessly posted (Mozilla/5.0 (iPad; CPU OS 6_1_3 like Mac OS X) AppleWebKit/536.26 (KHTML, like Gecko) Version/6.0 Mobile/10B329 Safari/8536.25)
There are 3 main players. Globalstar, Irridium, and MSat
Globalstar, and Irridium. Are actual portable phones. I do not believe that the Combo phones are worth getting, as they were either GS/Analog or GS/CDMA if the US is anything like Canada, we can kiss original CDMA goodbye in 2-5years so that spectrum can be used for UMTS/HSPA. Irridium phones are only usable on the satellite network. MSat phones are not handheld, they require a self aligning antenna, and due to using a satillite over the equator, suffer from significant propagation delay, upwars of a full second to speak and get a response.
You really do not want to go Satphone route, it is EXPENSIVE, not only for airtime, but monthly service as well. You also need to be aware that 911 does not work when using a Satphone.
If you really require a Satphone because you are going somewhere there is not any cell service, look at renting a Satphone from a comms provider. Here in Alberta most 2-way radio shops rent satphones , for short term or long term use. Be warned it is not cheap to do
I'll add to the excellent advice above...
I have an Iridium satellite phone at work and for a no minute monthly plan it's about $45. Air time is around $1.55 US per minute. I rarely use it, so this is an acceptable plan for me. If I were to use it more often, you can purchase plans that include minutes, but they get pretty expensive.
The phone is a Motorola 9555. It's a satellite only phone, and while not the newest model, has a good track record. The phone, new, was about $1500. That included a lot of accessories, such as charger, external magnetic mount antenna, case, handsfree cord, etc. Due to the price of the phone and it's intended use as an emergency option, I purchased a Pelican 1200 case to keep it all in. Since it occasionally gets loaned out, I wanted a case that everything went into and was kept together.
As for the air time plans, you need to figure out if you want a USA phone number, or if you are willing to use the carrier assigned number international number. The difference depends on if you want those calling your satellite phone to be able to call you via a less expensive route, or use the international calling route. There is a cost difference, but I can't remember what it was for my phone. Since I use it for calling out, I went with the cheaper international number.
I'd second the advice about renting. Unless you need to have one in your possession all the time, it might be an easier route.
Also, you don't get your service directly from Iridium, you buy it for a reseller. I'm using SatWorx, and have had mixed results. I pay via a purchase order, and they can't seem to properly bill us consistently. I'd say shop around, the prices are all pretty much the same, but what you get from them is slightly different.
kayn1n32008
Sector 001
Mmkenna's advice is spot on. Although you can get northamerican numbers from Globalstar, MSat is different. When I was living in Yukon Territory, working for a comms company, our MSt phones all had 1-600-700-xxxx phone numbers.
Interesting.
Well, the phone number is tied to the SIM, so I guess you'd get whatever temporary number was on that card.
As long as you keep minutes on the card, you keep the number.
The 75 minutes are only good for one month, and you have to add minutes to keep the card active after that month. The big question is "what increment of minutes do they make you buy to keep the card active? and, how much are those minutes?"
While that doesn't tie you into a contract, it does tie you into paying on that card as long as you want to keep those minutes. After a while, you will likely end up with a lot of minutes on that card if you don't use them up.
Seems like a PITA.
