Save replay audio with Proscan
Jondrew55
Oviedo, Fl
My understanding was that when you enable replay (not record) on the SDS 100 it keeps the audio file in a folder called inner_rec that you can find when hooked up to the micro ssd chip. I thought you could then save that file so you had a copy of the latest replay file. But that does not seem to be the case. I don't know if Proscan offers a way to access the replay audio, or if it just is erased after you listen to it.
I know this question has been asked before, but I have not seen a satisfactory answer in my searches.
dave3825
Suffolk County NY
Don't know the answer on that, but if you set up Trunking Recorder, and import calls from your scanner, you can play back anything at any time (that your scanner received) based on how long you retain recordings in Trunking Recorder.
kruser
Well Known Member
W St Louis Cnty, MO
You can access those recordings as long as you have Set Replay Duration set to anything other than Off.
But... the audio files only remain in the inner_rec folder for the length of time you set in the replay duration menu.
The files are automatically deleted when the replay duration time is reached for each file.
So basically, if you just heard something and didn't have normal recording turned on but did have Replay recording on, you need to plug in a USB cable and put the scanner into mass storage mode quickly and then grab your files with explorer or whatever you use for a file manager because they will go away when the timer expires.
I've done this a few times on the SDS and x36HP models. They all work the same.
I never used recording with the HP1/2 models so I don't know if this trick works with those models.
The files will not delete automatically just working with the files on the SD card. The delete command is a function of the scanner.
Whiskey3JMC
Google-Foo Ninja 4 Hire
Simulcastylvania
You can. Connect your SDS100 to your computer (Press "E" when prompted to put scanner in Mass Storage Mode) It should show up as a removable drive in Windows Explorer. Navigate to said folder and copy it to your computer's hard drive. You can use Universal Scanner Audio Player to play the mp3s contained within & display all tagged info
jtwalker
I was going to try to explain this as well as you just did but didn’t have the energy to type this much.
To the OP, as you can see from @kruser’s explanation it can work but having to stop scanning and put scanner in mass storage mode makes it something you aren’t going to want to do very often.
kruser
Well Known Member
W St Louis Cnty, MO
But like I said above, the files are automatically deleted if the Replay Duration time has passed since the inner_rec files were created.
So one needs to grab them before that timer deletes them. That timer has a max time of 240 seconds which is the default time I believe.
Jondrew55
Oviedo, Fl
Thanks all. I work from home and now have my scanner running all the time. While I can get some dispatch and operational police, fire, and EMS I also get the local University, public works and school bus traffic from the local counties. I've heard some doozies over the last week or so. It's nice to be able to replay them, but to save them I've played the scanner into the phone. Maybe I should just set it to Record, but I'm not sure I want to store a bunch of mostly garbage filling up my SD card.
dave3825
Suffolk County NY
Hate morning
Forgot to mention trunking recorder with proscan.
Jondrew55
Oviedo, Fl
You're right. I'd forgotten Proscan has a recording function. That sounds like it might be what I need.
Ubbe
Stockholm, Sweden
If you enable recording by Func+Replay and then disable it again by Func+Replay it will immediately save the temporary inner replay recording files, that haven't yet timed out, to the permanent user recordings folder.
/Ubbe
seagravebuff60
Short Bus Reject
Snow Bird
Ive been using Uniden Scanners for Years. I highly recomend to everyone to use Uniden scanners paired with ProScan. It's worth the money.
Back in the day, I had Proscan do all the audio playback. Of course, I had to have an AUX cord running to the computer to achieve recording. I had the retention period set to forever, so I always had the recordings. Proscan has an internal feature that allows users to play back right in the ProScan app. I also had the MP4 files saved to my NAS, so I was able to listen anywhere in my house. I also used Universal Scanner Player as well, I recommed it as well, even tho it is not my favorite.
Eventually, as I needed to access the recordings outside of my network, I turned to the webserver. It was good for the time being. Also, Around that time, I also got into SDRs, UT, and SDR Trunk and used a Trunking Recorder to listen to that stuff.
After a few months, it got annoying to listen to up to four Proscan webservers and a Trunking recorder simultaneously. I thought it would be easier to access everything in one interface, so I strongly favored the Trunking Recorder Interface over the ProScan webserver.
I was one of the originals who recommended that the Trunking Recorder integrate with Proscan, and after much testing, the TR developer made it happen. The integration is 100% what I was looking for, and is absolutely great, so now I can listen to my Scanners and SDRs in ONE listening interface. Also, recently Trunking Recorder has integrated with DSD+ so you can also listen to that as well.
TLDR: Use ProScan and pair it with Trunking Recorder. I guarantee it will meet your expectations.
