I hear nothing when listening to Sayerville with SDRTrunk. I'm in Old Bridge, at the border with Sayerville. System downloaded directly from RadioReference: Control, Single, LSM, all 4 frequencies are control. Any help is appreciated.
Assuming OP is referring to Sayreville Simulcast here. Sayreville law enforcement is entirely encrypted as denoted by mode "TE" talkgroups and therefore cannot be monitored. Only Fire, EMS, DPW & schools talkgroups not designated as "TE" can be monitoredWhat band are these frequencies?
I Do not ' SEE ' any other activity. Listening to NJICS and Old Bridge works fine. The only anomaly is with Sayerville. If I compare with Old Bridge, there are many EMS calls per hour. True, it can be silent for some time, but I can listen to Sayerville for HOURS with nothing.It looks like you've got the channel setup correctly, it's locked onto the control channel, and it's obviously receiving call grants as we see the PD is active. We also see that you setup an alias list for the system, and if you used the import from RR feature, it should've set all of the unencrypted talkgroups to Listen = yes, but double check that. Also double check that the audio output device is set correctly, and that you've built the JMBE Audio Library, otherwise it's not going to decode any voice.
Finally, you should clarify whether you can't hear any non-PD activity, or you don't see any non-PD activity. You stated both, but they're kind of two different things. If you never see any other activity besides the PD talkgroup(s), then you're obviously not going to hear anything. If you see unencrypted traffic, but don't hear anything, that's entirely different.
Could just be that the other talkgroups are seldom used. Have you verified with a scanner or other receiver/software?
Thanks! That suggestion works. Listen to Middlesex County, but listen ONLY to Sayreville/South Amboy Talkgroups.not sure if u found a resolution to this, but if not try programming the mdsex county system and just putting in sayreville TG, i hear them all day through the system, i know this doesn’t solve the issue of why tour not hearing them on their own system but at least u will be able to listen
