Scan 2 different Trunk Systems
jeffycc
Nashua NH
Can you scan 2 different trunk systems.
I'd like to scan Nashua NH FD and Manchester NH FD in a single knob.
Thanks!
APX8000
Sarcastic Member
AES-256 secured
Im using it in Beta. It misses a lot of traffic compared to my APX8000.
CFP387
Rowan County, NC
Not yet, this concept is still in beta testing
If the original poster is asking about monitoring two systems at the same time, I believe that Unication representatives have said that the technology isn't out there yet. The best we can do currently is monitor two systems individually in a scanning environment where the unit will switch from one system's control channel to the other with the minimum hang time of one second.
In using this feature, I have missed traffic on one or the other systems and, rightly so because the unit needs time to find the second control channel after dropping the first one.
pro106import
Milford, Ct. perched high above Long Island Sound
I take it you have the version 1.4 beta firmware to be able to do this?
CFP387
Rowan County, NC
Yes sir, I did but had to revert back to v1.3. My pager would operate fine for about two days and then the audio would mute. I had to revert back to v1.3 to for the pager to operate properly again. This only happened the three times I would try to run v1.4.
pro106import
Yes I remember reading your posts about that. So in 1.3 firmware, I didn't know the pager would drop one control channel to scan to another by itself. How did you set it up to do that?
CFP387
Rowan County, NC
Only in the v1.4 firmware is this possible. The pager switches from one system's control channel to the other. You will miss traffic because the pager cannot scan both systems simultaneously.
mitbr
Tampa Bay Florida
To the OP. The only way to do this efficiently is to have 2 radios. It gives you an excuse to buy another one.
Tim:cool:
dcr_inc
Not an EXPERT !!
Delta, Pa
Even with 1.4, the transition between systems is SLOW.. 10 seconds or longer between system lock on.. The G series will ALWAYS be a PAGER, never a scanner (Or APX radio)
GTO_04
Noblesville, IN
That is slow! I had no idea. 1 second would not be so bad though.
GTO_04
CM1
Central, NJ
I have the beta 1.4 firmware installed and the ability to scan more than a one trunked system does NOT exist on my G4.
Sure I can create/program everything in the PPS. However when it comes to the actual pager once I choose Trunking Free Scan the Pager TG List and User Define Scan can't be chosen/selected (so nothing I created in the PPS is available within the pager).
trido
Retired 32 years scanner sales
Southern In
May I ask and YOU had NO issue going from 1.4 to 1.3?
trido
Southern In
This isnt a great video from this character, however he shows that YEs it works.I do and can scan more than one system.You scan multi KNOB pos.See if this video helps at all. Again it is poor quality made but has tips.
Be SURE your knob pos are tg scan and not tg MONITOR.If you have one set as monitor change it to scan and just add wildcard TG to that system.
CM1
Central, NJ
I appreciate the video & tried it - same results :(.
There's a handful of us out here with the same issue - a guy on on the FaceBook group posted an identical video showing the issue, so I'm hoping a revised beta solves it. Hopefully, Unication has been listening us?
