"scan sweep" timer for XPR 3300
codyw720
I have a customer that is complaining about getting the beginning of calls cut off. I'm assuming that is from the radio taking its time cycling through all the channels.
This is a DMR system with the radio scanning 4 channels. I tried looking it up and I saw there is something called "scan sweep" to change the time it takes to scan through the list. I am not seeing anything like that in the CPS 2.0 software.... Is it hidden somewhere? Does the radio even have the ability to adjust that?
K2NEC
5F6
No such thing as scan sweep. If you dont want users missing calls, either set up priority scan or disable it entirely.
codyw720
Is it just not able to be adjusted for this model radio? It shows it in the help screen in the software
K2NEC
5F6
I see that in the help file, but I dont see it as an option anywhere either. Im gonna still stick with my, use priority scan or disable scan entirely answer.
RFI-EMI-GUY
Is this an IPSC system or are these disassociated channels? If IPSC it should scan for a beacon and stay there for a while (dwell).
codyw720
I'm not too sure what IPSC is. Is that What Capacity Plus is? I don't work much with Motorola radios so I'm still kind of learning the product.
It's a DMR conventional site.
RFI-EMI-GUY
IPSC is a multisite linking protocol for tier two, conventional Mototrbo.
codyw720
Does anyone have an idea what I can adjust to speed up the scan speed? I know it's something that "it is what it is" but I don't know if Motorola has some sort of adjustment somewhere in CPS 2.0 for the XPR3300
tweiss3
Is it time for Coffee?
Ohio
Only way to "speed up" scan is to reduce the number of things in the scan list.
K2NEC
5F6
Have you considered reaching out to Mototola for support?
codyw720
Is there a good number that I can reach them at? Do I have to be a dealer to get actual support?
The customer says they HAVE to scan these 4 channels. They are going from a trunking system to DMR conventional which is obviously going to be different when it comes to scanning.
I suggested that they just wait a second or two after the key up to start talking. Customers don't seem to like that answer though...
