Scanner code for pitman nj??
Pitman NJ
Hi,
What actually are you looking for? "Scanner code" Frequencies? PL Tone?
Radio Code (10-Code) or something else?
I need a little more information in order to help you out if I can:D.
loumaag
Silent Key - Aug 2014
Katy, TX
Scanner codes....
Repeating the same query when asked for clarification is a sure way to cause problems. There is no such thing as "scanner codes", so why don't you answer the question asked in post #2 and perhaps someone will be able to help you.
krs449402
Pitman NJ
sorry freq.. I know they dispatch there own station and not through central... The number I have does not work 500.400..??
DELCOLHFC
S.E. PA
what does input mean in the freq. section?? should I click show and input that number??
No, don't worry about the input, you would want the repeater's output freq, it will be much stronger and from a higher antenna.
krs449402
Pitman NJ
My buddie said that possibly they went DIGITAL??? I have no idea what that means but is that possible and would there be a list for that??
