Scanner for DPL/FMN
CB62
Hi.
I am new to this.
As I understand it, the FMN mode is an analogue FM, but the DPL tone is a private digital signal?
Will an analogue scanner work for this tone/mode combination?
For example:
453.3875WPWL336RM065 DPLMdlsx D14 NoD14 North Operations / Local Eventl Green (Simplex)FMNFire Dispatch
453.700WNVN480RM065 DPLMaynard PDPolice Operations PrimaryFMNLaw Dispatc
ecps92
Taxachusetts
Hi.
I am new to this.
For example:
Any (of Recent Years, not decades ago) Analog Scanner that can handle PL (CTCSS) and DPL will work for those two frequencies. (At this time)
DPL is a different format, but very similar to PL/CTCSS
(At this time) with many PD's moving to P25 you may want to invest in something for the future
What are you currently using ?
W1KNE
Chief Jabroni
New England
PL is short for "Private Line", which is the trademark name for Motorola's version of CTCSS. DPL is short for Digital Private Line.
A PL tone is nothing more than a octave transmitting at a single frequency. i.e. 131.8 Hz. You can usually "hear" the PL tone because it is within the audible range. DPL is a digitally coded version of that. Nothing more than that. It's still within the analog audio range and part of analog transmissions.
CB62
I don't own a scanner yet, but I am considering the B125 to get started.
MiCon
Mike
central AZ
Hi.
I am new to this.
For example:
The short answer is yes. PM me for a more detailed explanation of why PL, DPL, and CTCSS are used.
