scanner Programing
MFD616
LONG ISLAND
I have a Uniden BCT15XT scanner that's been programmed for a while, and I'm looking to update it. Does anyone have update frequencies that I can upload into ARC XT software for Long Island and NYC?
GTR8000
NY/NJ Database Guy
BEE00
You're a premium subscriber, use ARC XT to import whatever analog channels you want to listen to from the RRDB.
wtp
Port Charlotte FL
like gtr8000 posted, if you use a program to set up the radio you will have the latest frequencies.
or do you mean a firmware update ?
the latest firmware update for the bct15X is 1.07.00
1.07.00 - Released 10/8/2021​
Housekeeping update to accommodate revised hardware - No functional change from 1.06.03.
MFD616
LONG ISLAND
I probably need both done I haven’t not done any updated with anything since I owned it
wtp
Port Charlotte FL
check the firmware version first,
To Edit Settings press MENU. Scroll to 'Settings' and press E/●.
Scroll to the settings and options below and press E/●.
Firmware Version and Serial Number allows you to view the firmware version, the serial number, and the checksum and version. It is recommended that you download and install the latest firmware upgrade for the scanner if you don't already have it. Check the Wiki to find all the information necessary to upgrade your firmware.
Scroll to 'See Scanner Info' and press E/●.
Scroll to 'Firmware Version' and press E/●.
Press MENU twice to exit.
