I agree that they are of limited usefulness for day to day scanning. That's why the manufacturers do not make this a priority, and why the best we get is a little 5-bar mini-meter on even the best scanners. However, there are certainly uses for them. Your ears will tell you if a signal is good or not. But your ears will not tell you the difference between good, better, and best, nor will they give you any way to quantify that. Do you need that ability everyday? Probably not. Most scannists probably never need it at all. But serious scannists will occasionally like to experiment with different antennas, different antenna mounts, different antenna locations, different coaxes, different preamps, and different attenuators. The only way to quantify those differences will be with some type of signal strength meter. Not all of us have access to a ten-thousand dollar service monitor, you know. Regardless of how technically accurate you feel an S-meter is, the fact is that it does give us an objective way to measure performance, and some of us need that.
