Did some reprogramming as our county is going P25. I am using Freescan. This scanner was receiving P25 full scale before and still works good on conventional. Nothing on P25. Where should I look on the program
Mike
Mike
Yes. For the 996P2 change the scanner type in ProScan, then go to the Database tab, then create/open a new database. You can then read the scanner's current programming to work with that.Wait... I found it! I had to open a database in Proscan first to get the window.
By "items" do you mean Groups of talkgroups within a system? The 996P2 has the hierarchy of System, then Group (groups of talkgroups), then Channel (talkgroups). What limit of 20 are you referring to?Thanks! I got iit working and receiving. I was wondering since the scanner only allows 20 items in a single list so I will make 2 lists (favorites). Do I have to put in the transmitter sites in both lists or will it work if they are in just one?
That odd. I just imported the entire system from the RRDB into ProScan at once, no issues, no warnings...all talkgroups came through just fine.When I go to program the radio with CORNet it only allows 20 departments at a time. Monroe, Middletown...up to 20. I have to download the next 20 departments to a separate group. I hope I got the terms right......
Can you create another system and drag & drop the nodes?If I click continue, it breaks up some of the departments and add them to the first system on the list.
I will give it a try.Can you create another system and drag & drop the nodes?
or copy the system to a new system then select all the nodes to delete then delete.
Ah okay I see what's going on now. It's running up against the limitations of the scanner itself, not ProScan.Here is the warning I get when it try to add the entire system to my 996P2
| Blooming Grove PD | East |
| Cornwall PD | East |
| Maybrook PD | East |
| Montgomery Town PD | East |
| Montgomery Village PD | East |
| New Windsor PD | East |
| Newburgh City PD | East |
| Newburgh Town PD | East |
| Walden PD | East |
| Washingtonville PD | East |
| Chester Town PD | South |
| Chester Village PD | South |
| Florida PD | South |
| Greenwood Lake PD | South |
| Highland Falls PD | South |
| Highlands PD | South |
| Monroe PD | South |
| Tuxedo Park PD | South |
| Warwick PD | South |
| Woodbury PD | South |
| Crawford PD | West |
| Deerpark PD | West |
| Goshen Town PD | West |
| Goshen Village PD | West |
| Middletown PD | West |
| Mt Hope PD | West |
| Port Jervis PD | West |
| Wallkill PD | West |
