K9GTJ
It ran fine forever v.13 but quit after some Microsoft Updates. Now v.13 and v.14 crash...
Here is the v.14 error just trying to configure it...
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Configuration.ConfigurationErrorsException: Configuration system failed to initialize ---> System.Configuration.ConfigurationErrorsException: Unrecognized configuration section system.serviceModel. (c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Config\machine.config line 134)
at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
at System.Configuration.BaseConfigurationRecord.ThrowIfParseErrors(ConfigurationSchemaErrors schemaErrors)
at System.Configuration.BaseConfigurationRecord.ThrowIfInitErrors()
at System.Configuration.ClientConfigurationSystem.EnsureInit(String configKey)
--- End of inner exception stack trace ---
at System.Configuration.ClientConfigurationSystem.PrepareClientConfigSystem(String sectionName)
at System.Configuration.ClientConfigurationSystem.System.Configuration.Internal.IInternalConfigSystem.GetSection(String sectionName)
at System.Configuration.ConfigurationManager.GetSection(String sectionName)
at System.Configuration.PrivilegedConfigurationManager.GetSection(String sectionName)
at System.Diagnostics.DiagnosticsConfiguration.GetConfigSection()
at System.Diagnostics.DiagnosticsConfiguration.Initialize()
at System.Diagnostics.DiagnosticsConfiguration.get_SwitchSettings()
at System.Diagnostics.Switch.InitializeConfigSettings()
at System.Diagnostics.Switch.InitializeWithStatus()
at System.Diagnostics.Switch.get_SwitchSetting()
at System.Diagnostics.BooleanSwitch.get_Enabled()
at System.Xml.Serialization.RecursionLimiter..ctor()
at System.Xml.Serialization.XmlReflectionImporter.IncludeTypes(ICustomAttributeProvider provider)
at System.Web.Services.WebMethodReflector.IncludeTypes(LogicalMethodInfo method, XmlReflectionImporter importer)
at System.Web.Services.WebMethodReflector.IncludeTypes(LogicalMethodInfo[] methods, XmlReflectionImporter importer)
at System.Web.Services.Protocols.SoapClientType.GenerateXmlMappings(Type type, ArrayList soapMethodList, String serviceNamespace, Boolean serviceDefaultIsEncoded, ArrayList mappings)
at System.Web.Services.Protocols.SoapClientType..ctor(Type type)
at System.Web.Services.Protocols.SoapHttpClientProtocol..ctor()
at ScannerCast.RadioReference.RRWsdl..ctor()
at ScannerCast.ScannerCast.RetreiveFeedInfoFromRr()
at ScannerCast.ScannerCast.GetFeedButton_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
