ScannerCast Crashes...
K9GTJ
Kokomo, IN
It ran fine forever v.13 but quit after some Microsoft Updates. Now v.13 and v.14 crash...
Here is the v.14 error just trying to configure it...
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Configuration.ConfigurationErrorsException: Configuration system failed to initialize ---> System.Configuration.ConfigurationErrorsException: Unrecognized configuration section system.serviceModel. (c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Config\machine.config line 134)
at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
at System.Configuration.BaseConfigurationRecord.ThrowIfParseErrors(ConfigurationSchemaErrors schemaErrors)
at System.Configuration.BaseConfigurationRecord.ThrowIfInitErrors()
at System.Configuration.ClientConfigurationSystem.EnsureInit(String configKey)
--- End of inner exception stack trace ---
at System.Configuration.ClientConfigurationSystem.PrepareClientConfigSystem(String sectionName)
at System.Configuration.ClientConfigurationSystem.System.Configuration.Internal.IInternalConfigSystem.GetSection(String sectionName)
at System.Configuration.ConfigurationManager.GetSection(String sectionName)
at System.Configuration.PrivilegedConfigurationManager.GetSection(String sectionName)
at System.Diagnostics.DiagnosticsConfiguration.GetConfigSection()
at System.Diagnostics.DiagnosticsConfiguration.Initialize()
at System.Diagnostics.DiagnosticsConfiguration.get_SwitchSettings()
at System.Diagnostics.Switch.InitializeConfigSettings()
at System.Diagnostics.Switch.InitializeWithStatus()
at System.Diagnostics.Switch.get_SwitchSetting()
at System.Diagnostics.BooleanSwitch.get_Enabled()
at System.Xml.Serialization.RecursionLimiter..ctor()
at System.Xml.Serialization.XmlReflectionImporter.IncludeTypes(ICustomAttributeProvider provider)
at System.Web.Services.WebMethodReflector.IncludeTypes(LogicalMethodInfo method, XmlReflectionImporter importer)
at System.Web.Services.WebMethodReflector.IncludeTypes(LogicalMethodInfo[] methods, XmlReflectionImporter importer)
at System.Web.Services.Protocols.SoapClientType.GenerateXmlMappings(Type type, ArrayList soapMethodList, String serviceNamespace, Boolean serviceDefaultIsEncoded, ArrayList mappings)
at System.Web.Services.Protocols.SoapClientType..ctor(Type type)
at System.Web.Services.Protocols.SoapHttpClientProtocol..ctor()
at ScannerCast.RadioReference.RRWsdl..ctor()
at ScannerCast.ScannerCast.RetreiveFeedInfoFromRr()
at ScannerCast.ScannerCast.GetFeedButton_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
K9GTJ
Kokomo, IN
Looks like KB983583, KB2418241, KB976576 installed for .NET framework 2.0 SP2 just today.
K9GTJ
Kokomo, IN
I uninstalled the recent updates and then did a system restore to 10 days ago it still doesn't work.
K9GTJ
Kokomo, IN
I ended up going to add/remove programs and selected the latest version of .net (3.5) and clicked uninstall. I was given the option to remove or repair to original state. I chose repair and life is good again!
