Scanning Banks on 796D (Help!)
Skylab
San Diego, Ca
Hello. I'm new to this scanner, but not to the scanning world.
My question is: How can do I get the radio to scan only one Bank ID List at a time?
This is what I've been doing and the radio scans all of the Banks I have programmed in the radio:
TRUNK: Select Bank
Bank 3 E Scan
It will not stay within Bank 3...it goes thru Banks 1 and 2 (the only other ones programmed in the radio.
This seems like such a simple thing to do, monitor just one Bank.
Thanks for helping a newbie out.
Craig™
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Press the number 3, then 1 then 2. This should put your scanner in bank 1, 2 and 3, then 2 and 3 and finally 3 alone. Remember though, if you are in ID SCAN Mode, pressing the numbered keys will select/deselect scanlists. ID SEARCH Mode is best for selecting/deselecting banks.
LarrySC
Greenville, SC
On the 796d all of the bank numbers show on the screen in large font in the SCAN mode. Press any number to turn them on or off. If its off the number does not show. In ID SCANNING of trunking talk groups all ten list for each bank will show. Usually you would have only two or three in use. Turn them on or off the same way.
