scannerface27
alright, ive been scanning laso for a while now, and know about the high 480 system they are on. What ive been doing to scan them is just put in the base, and mobile frequencies. Sometimes ill get the beep beep. and sometimes depending on where i am, ill get some feild traffic.. Which brings me to my question, as i was programming my 396xt, i read the little article on the database, before the frequencies, that explains this. see paragraph below...now does this mean if i put in the ltac frequencies i will here the feild units... or do i have to put in the input freqs, and what are they....????? here is the article I was talking about.. mainly Los Angeles County Sheriff's Department operates a conventional radio system referred to as the "480 System" within the department, because of the frequencies it occupies. The system uses over sixty repeater sites around the county, most of which are on hilltops, to relay communications. The hilltops from which a particular repeater transmits from is dependant upon the area that channel was intended to cover. Communications on a particular channel will sound the best when monitoring from within or near the area that the personnel assigned to that channel patrol.
With the exception of Special Units Dispatch (which has countywide coverage), Dispatch and Local Tactical channels each have the smallest area of intended coverage. As a result, a listener must be relatively closer to a particular dispatch area to hear communications on that channel clearly. Conversely, Area Tactical and Countywide Tactical channels each are intended to cover the territory of several or all of the dispatch channels combined. As a result, listeners can hear communications on any given Area Tactical and Countywide Tactical channels from further reaches of the county than corresponding Local Tactical or Dispatch channels. While these repeater configurations provide varying degrees of expanded coverage on a particular channel, personnel may bypass the repeaters and use simplex on any channel, commonly referred to as "direct", "talk-around", or "car to car" operation.
The Sheriff's Communications Center (SCC) is located in East Los Angeles near the Biscaluze Jail, and dispatchers all incidents countywide. To assist SCC in confirming who is transmitting, each time a deputy presses the transmit button on his radio the radio transmits a unique identifier (called a "G-Star AID", "burp", or "burst" encoder, or more commonly a "turkey call"). The unique IDs are displayed on the SCC dispatcher's screen. When a radio's emergency trigger (also called "E-Trigger" or man down switch.) is activated, the radio switches to the emergency channel and transmits the Radio ID five times.
Each sheriff's station has a Dispatch channel and a Local Tactical ('L-TAC') channel, each of which may be permanently shared with one or more other stations depending on the volume of station radio activity. Nearly all incidents and communications begin on a Dispatch channel (and then could switch to L-TAC / A-TAC / C-TAC or STAR-TAC). This last pargraph is what i am inquiring about.. NOTE: Mobile traffic is not rebroadcasted over the output frequency of the dispatch channels. Instead, only a beeping tone is broadcast to signify to the field units that someone is talking. To monitor units in the field you must program in the input frequencies also. The corresponding L-TAC channel is included in brackets.
