Scansets on WS-1080
W6KRU
Vista, CA
I can't modify scansets in EZScan. The default in the software is everything assigned to Scanset 1 and I can't change that or rename scansets. What am I missing?
mikey60
Oakland County Michigan
Where are you not able to change the scanlists? During import or elsewhere? Just tried it here and had no issues once I've selected the channel(s) to change and then click on the scanlist column.
Mike
W6KRU
Vista, CA
Mike
The scanlists are fine here. The scansets are the problem. I can't modify scansets on the advanced tab of EZScan.
W3DMV
Gettysburg, Pa
I have a PSR800 and assume the software is still the same.
The only selection I have:
Open software
Click on advanced tab at the bottom
With the advanced page open, look at the top right of the page
is labeled "scan sets"
click on scan set mode and make selection and see if that fixes the problem.
baayers
Pinellas County FL
Open software
There appears to be a glitch in 2.0 of the software that is preventing us from being able to do anything with ScanSets. For whatever reason I cant rename, select ScanLists, or even enable or disable them. You can see everything but clicking does nothing.
software
Can someone send me the software so I can look at it?I would like to see why the scansets dont work.
rwier
Phoenix, AZ
Is the "2.0" (assuming EZ Scan?) Software only available to those with a WS-1080? I have the GRE 800 and a quick check shows I am up to date with Vs-1.8 ? Just curious.
Thanks,
rwier
rwier
Phoenix, AZ
Thanks,
rwier
I think I found my answer after reading another thread. Ignore previous, and sorry for not keeping up, lol.
