Just curious if anyone knows if this system can be setup with roaming in a DMR portable or mobile so that it would automatically use the closest repeater for whatever talkgroup is selected, similar to an IP Site Connect setup. Currently I've got it setup with a zone for each repeater and assigned channels in each zone with the talkgroups. Sometimes if I'm between two zones and I'm scanning I'm not sure which repeater (especially with local) is being used. If it could be setup as a roaming profile that would make things easier. This would be for a XPR3500e, 7550 and 5550.
