Screen flickering...ughh
WeBeCinYa
NC
My newer 200 now has the screen flicker. The other locked threads on this didn't really provide much of a resolution. I assume this has to be sent in to customer service now to correct? Shame its only 2 months old and the screen flicker is insane.
frazpo
SW Mo
Yes. Just got mine back. Same issue. Covered by warranty of course.
mitbr
Tampa Bay Florida
I'm unsure why the default response to a problem with a SCANNER radio is followed by the response of why dont you buy a pager. Lol. Two different products guys. Most scanner hobbyist cant get what they need out of a pager.
Its a response to the OP specifically I am not suggesting people buy a pager instead of a scanner and the OP already has the Unication! :cool:
radio3353
Mine did the same thing. I opened it and made sure all cables were set properly. Didn't fix it. Fortunately (?) it happened rather quickly so I returned it for a refund. Done with this series of scanners. Hopefully they can make a future product as solid as my BC780XLT - 19 years old and still on my desk scanning away. I used Amazon so I was not out any money. I was so happy to get a hum free unit and then the screen problem happened. :censored: I hope you get a good resolution.
WeBeCinYa
NC
Maybe someone can chime in that’s had same issue and let us know what repair was performed by Uniden.
frazpo
SW Mo
I just had the same issue. They replaced the display and a ground wire. I'm hoping I dont have the hum. I repaired the hum by removing laquer from the display board to properly ground the display to the frame. Now that I have a new display I suppose the hum may return. Havent been home to find out yet.
fxdscon
¯\_(ツ)_/¯
greggk
York,PA
If you take the radio apart and try to fix it, then send it to Uniden, they may not honor any warranty if they discover its been tinkered with. FWIW. IMHO. Greg
frazpo
SW Mo
I knew that when I repaired it. It's been in and returned so I guess it didn't matter. The repair I completed was the only 100% cure for the hum.
greggk
York,PA
I was NOT criticizing, only offering a tip . I'm not sure what its all about now..lol. Greg
SteveSimpkin
Lancaster, CA
frazpo
SW Mo
I didn't think you were criticizing at all. Guess you read more into my comment than there was. Sorry.
werinshades
Chicago , IL
Is it possible the "hum modification" caused this? I've wondered whether the design had any purpose?
