SDS100/SDS200: Screen protector found
klinquist
Just installed the BestSkinsEver.com screen protector on my SDS100. Fits *perfect*... so for anyone else wanting to order one, you have to specify a custom size, then order with these specs:
Width 38mm
Height 51
Corner Radius 0
Film Glossy
Over All Size 200 x 140 mm
You'll see lots of 'imperfections' in my pic - that is water that will go away and become clear within about 12 hours.
You just peel away the bestskinsever and dip it into a bowl of water that contains a single drop of dish soap. Don't be afraid to get it completely soaked - this lets you move the skin around on the screen once you set it down.
Use a credit card or something as a squeegee if necessary to get all the water out.
jonwienke
More Info Coming Soon!
VA
And it has GPS active, but no cable plugged in...
Markb
Planet Earth
Good to know! I purchased a screen protector by Skinomi and cut it to fit. Sounds like the same material but without the extra work!
...and there's an extra LED above the screen :)
mrkelso
NNJ
Now that i see it i just ordered one. Free shipping
Markinsac
Sacramento, CA
Did you make your measurements using their suggestions for a slight gap? Just trying to make sure I don't have something that is too tight.
Also, after getting your screen installed, do you see any benefit to using the radius value to round the corners a bit?
racing1
Just ordered mine cant wait. Priority shipping.
Sent from my SM-G965U using Tapatalk
klinquist
I just measured with my digital micrometer and it turned out. As it dried overnight, it also shrunk just very slightly. I'm very happy with the size I bought, and I recommend staying with radius 0. No need for rounded corners.
Markinsac
Sacramento, CA
Thank you! Just wanted to make sure.
TailGator911
Silent Key/KF4ANC
Fairborn, OH
Jon - about your gps mod...Can you describe the light configuration, what it does, what color(s) etc. I see the gps light is a tad bit smaller than the stock LEDs and it is green. Does it change when signal is acquired? Steady on or flash? Just curious, thanks
jonwienke
VA
The light is solid green when the GPS has power, and alternates green and red when it has satellite lock.
For the SDS100, the GPS is wired directly, no switch. The GPS only reduces battery life by about 4%, and a switch would compromise the waterproofing. So the GPS LED doubles as a scanner power LED, and eliminates the need to have the alert LED flash when the screen is off to remind you the scanner is on.
racing1
Zip scanners now sells them in a 3 pack pre cut for the sds100 for 14.99.
AllenSchultz
Colorado
They also have them on there too for the 436
I just purchased one. It was about 3/64ths an inch too small. It had some bubbles initially, but those were no doubt my doing, and they went away in a few days. The protector looks nice, it is just too small. Confirm measurements with them before ordering.
WX4JCW
Stow, Ohio
i need to order one, but i need to get a replacement screen, somehow i scratched mine
