Scrolling With The Func. Knob ?
BOBRR
Boston, MA
Hello,
I have 10 FL's created, each with a QK.
I go to Set QK Status, and turn to ON, QK 1,2, and 3 in the SDS 200.
As expected 1,2, and 3 appear in the Display line F0, as numbers.
All the others have the *.
The unit now scans 1, 2, and 3 just fine.
Turning the Func Knob does nothing.
In Set Lists to Monitor, I have all 10 showing ON.
Question: why does turning the Func Knob not allow me to get to the FL's, other than FL 1,2, and3 3 FL's ?
I can get to them via the Keypad and the E, but not by turning the Knob.
Since the List has all of the FL Enabled, should I not be able to select the others without
having to use their QK; e.g., by just turning the Func. Knob ?
I guess I am asking what needs to be Enabled, etc., to be able to go from one
FL to another merely by scrolling with the FUNC Knob ?
Thanks,
Bob
Ubbe
Stockholm, Sweden
You have to make that a request for a new feature to Uniden, as it is not possible to do now. You probably have to enable FL scroll mode by a button, something like Fn+Zip.
/Ubbe
gmclam
Fair Oaks, CA
If you press MENU -> Set Scan Selection -> Manage Quick Key Status -> Favorites Quick Key; THEN you can use the scroll knob to browse through your FL. You can then select what you want On/Off by pressing E on each.
