UPDATE - the 536 does work fine when I took it on the road. Thank you Ubbe, JoeBearcat, hiegtx and ofd8001. I tend to believe hiegtx has the correct assessment regarding the "tuning" of the site tower. The site is located approx 15 miles from my location in open country and I'm on higher ground elevation. It has a 200' tower, 60' antenna with 100 watt output. The reason I posted that info is because my 200 on a discone, 25' up with lmr400, receives a maximum 3 bars signal but can be heard clearly. If I come across another discone someone is parting with I would love to try Ubbe's recommendation by cutting the elements. For the record, the sds100 with the remtronix rubber ducky receives at full strength. Thanks again for all your suggestions. At the very least, the sd card is "cleaned" and re-formatted.
The 'antenna tuning' can create issues. I ran into that several years ago.
Previously, one of the area suburbs, Grand Prairie, was on a Motorola Type II system (mixed mode, analog & P25 voice). I could receive that system at home, without a problem. In preparation for their change to P25 Phase II, and also joining the FWRRS system, they applied for modifications on their license. Obviously, they added the emission types for Phase II. But, buried in the comments for the modification, they also committed to the FCC to make other changes. First, they would lower the antennas on the towers, and refocus the pattern to their jurisdiction area. They also committed to using less power, since one of their frequencies was adjacent to a channel on a different trunked system in the area (Garland).
Once they moved to the Phase II system, I lost them entirely, even though their closest tower is only about ten miles away. Later on, I went to a business in that city, and while within their city limits, had no problems hearing GP. But on the way home, I lost reception about 4 miles east of their city limits.
