SD card read error
J-Wrock
Kansas City Area
Your scanner is having trouble reading the data off the SD card. What model of scanner? Assuming that you didn't take the card out at any point, then that suggests the card just wore down (it happens). To fix it, you'll just need to buy a new SD card less than 32GB in size, put it in your computer, use Sentinel to clear all user data on the card, write your favorites to the new card then put the card in the scanner. If that sounds completely confusing, there should be YouTube videos that show how to do this. The good news is your radio itself isn't broken and cards are inexpensive! :D
nessnet
What month is it?
It is suggested to use the SD Card Formatter program to format the card properly first.
THEN, do a clear user data in Sentinel.
mc48
Monroe County, NY
Take the card out and wipe the contacts with IPA and reinstall, if that does not help, remove it again and format the card, reinstall and then clear user data then write the program to the scanner. I use windows formatter and it always works.
dmchalmers
Thank you sir, I'll pick up another card an see what happens not sure if my laptop has a slot or i need an adapter. This same thing happened when i first bought my bcd436hp
dmchalmers
Was on my bcd436hp i was scanning an went to discovery to lock on a tower an i did auto store, check to db then hit discovery an boom.
dave3825
Suffolk County NY
The problem you’re going to face will be if you never had the sd card out before. On the 436 the card slot is in the battery compartment. It’s a real **** design and if one is not delicate, the hinged part will come off.
Not sure if you have to remove the card to try fixing it, but I would watch some of the videos on YouTube showing how to put the thing back together before attempting to remove the card.
Here is one such video from one of our members.
  • Like
Reactions: wtp
Chris0516
Pittsboro, North Carolina
@dmchalmers As mentioned above. The placement of the SD Card, in the BCD436HP, is. What I think of as, 'so close, yet so far'. Taking the battery out is the easy part. Sliding the latch, to remove the SD Card. Is easy, too. Because the latch has a spring connected to it. The real test becomes, when. You put any SD Card in the BCD436HP. That same latch will suddenly spring up, if. The SD Card is not secured properly.
I added a Youtube video:Replace/Insert SD Card on BCD436HP
