OP25 SDR CONFUSED
monitorboy
bay city ,midland,saginaw,mi.
What do i need or where do I go to find out what i need,to get started monitoring p25 phase 1 system(s).... I already have a windows 10 laptop and a RTL-SDR RTL2832U R820T2 TCXO+BIAS T+HF dongle .......TIA
waterbwuk
What system are you trying to monitor? Like @awasser1 said you may need two dongles, or even more, or possibly one. If you specify which system you want to listen to then we can give you a better idea of what you will need.
PDXh0b0
Woodland, WA
sdr trunk most likely will need two dongles.
One always needs more sdr's 😉
Was just a suggestion to get started with what he has on hand with 🤨windows😏
One does a decent job with 1 being there is only an option for a single audio output.
On this system
I dont notice allot a difference with 1, 2 or 3 sdr's.
monitorboy
MPSCS BAY COUNTY MICHIGAN P25 PHASE 1
waterbwuk
I'm assuming you only want to monitor one site/county, do you see the one you want to monitor on the list of sites for that system?
That system is covered by several people in several counties on the broadcastify calls system. You might get more of a better-suited response on the Michigan forum about specifically what you may need. Sometimes different software can act funky with different systems, they know that system best and can probably advise better.
