SDR# Gradient issue
Spleen
Westminster, MD
Has anyone figured out how to fix 1443's gradient problem? Everything is blue, and when you edit the gradient colors, it never gets saved. If you copy an entry from a previous version of SDR# into the 1443 config file, it's ignored and is deleted from the config file....
woodpecker
They changed the XML key, try adding this to the config:-
<add key="waterfall.gradient" value="4A0000,750000,9F0000,C60000,FF0000,FE6D16,FFFF00,FFFFFF,1E90FF,000091,000050,000030,000020" />
Spleen
Westminster, MD
Worked, thanks. I really should let my config file be overwritten once in a while...
