SDR# Mode Preset Plugin Display Help
thewraith2008
Glad you enjoy using the plug-in.
There is a mention of the plug-in on page 99 of the 2024 SDR# v1920 aligned edition of the book.
nj3h
Redmond, OR
Hello The Wraith 2008,
I continue to enjoy Mode presets and use it every day. I am using version 1.2.6.0.
Please see the attached pictures.
I have one local FM station that I want to be in mono only (not stereo), due to being weak and having hiss while in stereo.
When I uncheck FM Stereo and FM Stereo Enable on the Pre-Set Additional screen, then I click on the station button, FM stereo is reactivated. If I turn of Stereo on the Radio tab in SDR Sharp (1920 25 Apr 24) then go to the push button for the station in question, then stereo does not come on.
So what I am seeing is that the setting in the plugin for Stereo are not turning off the Stereo status within Sharp on the Radio tab.
Anyway, if you have some time, can you take a look at this? There is the chance that I have goofed something up.
Thanks so much.
Regards,
George, NJ3H
Redmond, Oregon USA
nj3h
Redmond, OR
Hi The Wraith 2008,
I am back to having issues as described above. I have turned off both FM Stereo boxes on the Additional setup screen and did a save. Now when I push on the particular station that has stereo set and then go to the station that I do not want stereo for, sdr sharp still has the stereo box checked on the radio plugin. I am using version 1.4.6.0. I am out of ideas.
Thank you,
George
